Wall Layers not joining
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
cadedu22
1001 Aufrufe, 11 Antworten
Wall layers are not joining correctly, why?
Same walls, with same height, with same parameters?
Pictures:
11 ANTWORTEN 11
Nachricht 2 von 12
RDAOU
als Antwort auf: cadedu22
@cadedu22
You probably placed them with "Disallow Joins"...select the wall and click the T sign to re-allow Join
Nachricht 3 von 12
cadedu22
als Antwort auf: RDAOU
I think it was visual bug,
I just simply clicked on wall and selected "Select Joined Elements" then every wall fixed it self...
I didn't even save file after fixing, next time opening it all was already fixed.
Nachricht 4 von 12
RDAOU
@cadedu22
No it is not a graphics glitch ...You are using Unlocked Layers with Base extension.... On the Ribbon
  1. go to Modify >> Geometry >> Wall Joins
  2. Then hover over the Corner >>> click to select >> Change to Mitter
Or Alternatively:
  • Disable Join on one wall only
  • Stretch wall to allow Geometry to Join following Layer function
NOTE: If you disable Join on both walls >>> You will need to manually invoke Join Geometry tool
Nachricht 5 von 12
cadedu22
Yes you are right, that wasn't glitch. Some how I adjusted a bit wall layers, and then pressed "Select all wall" I think that refreshed all lines and I though that that was visual glitch. In that other post I found what caused that.
Here what caused it and also fix (for people with similar issue):
https://forums.autodesk.com/t5/revit-architecture-forum/wall-layers-connections-messed-up-after-quot...
Nachricht 6 von 12
Actually @cadedu22 , there is a "glitch" associated with this - and 4 solutions.
Base Extension Distance changes how walls joins look graphically | Revit | Autodesk Knowledge Networ...
Nachricht 7 von 12
cadedu22
als Antwort auf: barthbradley
Oh so it was glitch, I simply used "Select Joined Elements" and it's fixed all walls.
Nachricht 8 von 12
RDAOU
That's not a glitch. It is the normal behavior of unlocked layers ever since that feature was there (I remember it dates back to 2009). That link to the incident is dated 2016, I wonder in Barth actually believes it is still under investigation!!!
There are 4 other workaround that article fails to mention, the most basic of which is  Converting the walls to parts
PS: Please mark any of his replies as a solution...
Nachricht 9 von 12
LMAO!  You get riled up so easily, @RDAOU!  Now you are all worked up about my use of the word "glitch" (in scare quotes)???  Geez. Next, it will probably be my use of the acronym BIM.  Oh wait; we've already been there and done that.
Take a nap dude. Maybe ease up on the meds too.
Nachricht 10 von 12
RDAOU
What caught my attention was the link not your reply and not how/what you punctuate, the latter are of no relevance. In addition to what has been already mentioned, the link suggests 4 workaround (not solutions) 2 of which I also do not believe are suitable for a workaround:
  1. Changing the view depth offset => floors as well as other elements invisible
  2. Resetting Base extensions to 0 => kills the original purpose of unlocking the layer
Nachricht 11 von 12
cadedu22
@RDAOU @barthbradley
Sorry, never meant to start a war, between you guys.
Nachricht 12 von 12
RDAOU
@cadedu22
Nah no war there ... that is just Barth's way of flirting :leicht_lächelndes_Gesicht:
