wall layer problom
wall layer problom
husamcivil
wall layer problom
husamcivil
Hi every one how can solve wall layer warp and what the meaning of warp at insert and end also what mean of both ,exterior and interior  , I have attached an image for more information
Ilic.Andrej
Based on the picture you gave, I assume your problem is not about the wrapping, but the wall joins. Use Wall Joins and play with these settings: "clean Join"/"Don't Clean Join".
If you wanna learn about wrapping though, this is how it works:
Wall layer wrapping at inserts is the wrapping of the window/door openings.
Wall layer wrapping at ends is the wrapping at the end of a wall.
Interior - All layers marked as "Wraps" and beyond the interior side of the core boundary will be wrapped.
Exterior - All layers marked as "Wraps" and beyond the exterior side of the core boundary will be wrapped.
Both - All layers marked as "Wraps" will be wrapped.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Corsten.Au
Hi
Get those Gyp-boardswrapwrap out of core, and wrap..
Corsten
Building Designer
Corsten.Au
Corsten
Building Designer
