Hello
Only, I am planning to extend the outer layer of my wall in plan view not in section. how i can do?
Please see the sample below
Thanks in Advance
Gelöst! Gehe zur Lösung
Gelöst von hmunsell. Gehe zur Lösung
You can't extend a wall layer in plan like you can do in section. In cases like yours I just another / separate wall type for the finish I want to extend. I think you can also use 'parts', although I haven't done it that way.
@revit1980 wrote:Hello
Thanks in Advance
Why? Sounds very strange. Where's this "Section" being placed? Can you post a screenshot of the "Section" View?
It is placing on the corner with the column.I asked if there is any possibility.Basically joining with structural column works very well But I dont know how can i do if the Structural Columns are linked as seperate rvt.
unfortunately the normal thing I would recommend only works in sections, not plan.
this is not ideal, but you can remove the exterior layer from your wall and place it as a separate wall. you would then have the ability to cover the column.
Howard Munsell
You could also use Create Parts to do it too i guess.... I don't usually like that method though.
Howard Munsell
My Pleasure....
I have been told I "write like I talk" (which is all over the place) so I find it easier to show when I can :-).
Howard Munsell
