Greetings all,
We are working on 3D printing mockup samples for various wall types (1:1) 800x600 (in 4 parts assembled like Lego tiles. The problem I am having is that we have several types which need to receive a 0.5mm metal sheet but Revit does not seem to allow any input less that ca0.8mm
Any ideas how to do this?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
However, I wouldn't model such thin elements in Revit...you might want to consider doing that using Inventor which is more suited for both, fabrication parts and CAM/3D Print
Alternatively
Model as one wall with finish layer (the metal sheet) as 1mm thick layer
Convert to PARTS...
Divide the 1mm layer into 2x 0.5mm
Exclude the outer part
Might be more useful if you need shape handles to overlap layers between the 4 pieces of the mockup assembly
Perfect! both work for me. Thank you. I will look into Inventor but for now it has to work in Revit.
