wall joint
19 ANTWORTEN 19
Nachricht 1 von 20
yazan.hijazeen
604 Aufrufe, 19 Antworten
wall joint
Hi everyone,
we have at our model this situation where 2 walls are connected, but because both have different hight dependencies , the connection is not clean, i tried to adjust it with the wall connection tool, but it does not work. Does anyone know how can I solve it? Thanks in advance.
19 ANTWORTEN 19
Nachricht 2 von 20
als Antwort auf: yazan.hijazeen
What are you trying solve exactly?
....where is the plan view cut plane located? Above that 3D geometry or through it?  If above  it, then the plan view looks correct to me.
Nachricht 3 von 20
I think it's all about the Plan View's View Range Cut Plane.  Does raising it or lowering it solve?
Nachricht 4 von 20
yazan.hijazeen
what i am trying to solve here, is to remove the line between the joint walls as shown in the screenshot to have a clean joint, I also tried playing with the viewRange cut plane, but it's not changing anything.
Nachricht 5 von 20
If you are actually cutting through all those walls - and they are joined - then that linework shouldn't be there.
Maybe Phasing? Set Phase Filter to Show Complete.
Nachricht 6 von 20
Nachricht 7 von 20
als Antwort auf: barthbradley
What is the condition at the base of these walls?
Nachricht 8 von 20
yazan.hijazeen
als Antwort auf: ToanDN
so all 3 walls share the same base level with no extension
Nachricht 9 von 20
yazan.hijazeen
so I did a quick test, where i drew walls as a chain and then modified the top constrain as required, the joint is still clean, but this means, the walls need to be replaced as a chain and this is not practical, as I have multiple similar situation.
Nachricht 10 von 20
Can you isolate the 3 walls and show a 3d view looking at the base?
Nachricht 11 von 20
yazan.hijazeen
Nachricht 12 von 20
The bases appear to be at different heights (maybe attached to something), are they not?
Nachricht 13 von 20
yazan.hijazeen
yes, they share the same base constrain, but attached to different Floors
Nachricht 14 von 20
Is your view Hidden or Wireframe?  Are walls category, or wall elements transparent?
Nachricht 15 von 20
yazan.hijazeen
the view is set to Hidden and walls are not transparent.
Nachricht 16 von 20
I am asking about the plan view, not the 3d view.
Nachricht 17 von 20
yazan.hijazeen
sorry, same settings in plan view
Nachricht 18 von 20
Can you share the file?
Nachricht 19 von 20
yazan.hijazeen
unfortunaltely, i can't share work related information.:verwirrtes_Gesicht:
Nachricht 20 von 20
Do you see the lines if you create a new plan view from scratch, not duplicating from another view?
