wall joint in elevation/3d
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
umbachdw
721 Aufrufe, 6 Antworten
I run into this fairly often - probably missing something basic....
In this model there is a wall at each story - so 3 levels in the image.
The walls are the same type, have the same finish and are exactly aligned. When the top two walls are joined the line between disappears, as it should.  I can't seem to get the joint to disappear between the 1st and 2nd levels.
What am I missing?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: umbachdw
Did you Split Face the first level walls?
Nachricht 3 von 7
Do you have unlocked layers?
Nachricht 4 von 7
RDAOU
@umbachdw
Double check how you placed the walls (Base and top constraints and the offsets)
Nachricht 5 von 7
The 1st floor wall was painted with a different material (DRK vs MED) even though they appear the same in your shaded view.
Nachricht 6 von 7
ennujozlagam
i agree with @ToanDN . deleted level 1 wall and copy the wall from level 2 and joined them and line will disappear. thanks
Nachricht 7 von 7
umbachdw
als Antwort auf: ToanDN
Well that was disappointingly easy.  Thanks.
