Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Wall Joins - Squared Off as default
12 REPLIES 12
Message 1 of 13
adveencha
684 Views, 12 Replies
How do I make my wall corners default to 'squared off', rather than having to use 'wall joins' to modify every corner?
Currently my corners look wacky and I have to use 'wall joins' modification on every exterior corner. See attached image.
Revit 2023.
12 REPLIES 12
Message 2 of 13
adveencha
in reply to: adveencha
Here is another example. The top walls defaults to wacky 'butt' joins. The bottom walls default to 'square off' joins.
How do I get all my walls to default to 'square off' joins, so I don't have to use the 'wall joins' tool on every single corner.
I have run through all the properties and type properties on both walls and can't find any setting that effects the corners.
Message 3 of 13
What is your wall assembly's layer function order?  If you order them properly then the walls should not join like what you show.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-M...
Message 4 of 13
Why don't you Miter the corners using the Wall Join Tool on the Modify Tab?
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M....
Message 5 of 13
adveencha
in reply to: ToanDN
Do you see something wrong in my assembly?
This is the assembly I've been using for years and it's worked until now, version 2023.
Message 6 of 13
Why don't you just allow auto-join?
Message 7 of 13
You have both finishes as finish 1. Change one finish to finish 2.
Message 8 of 13
adveencha
in reply to: ToanDN
I was hoping you were onto something but changing one of the finish 1 layers to finish 2 didn't work.
I have 'join status' turned to 'allow' when drawing the walls.
Message 9 of 13
Share your test file here because my Revot 2023 works the same as all other versions.
Message 10 of 13
How did the walls become unjoined? Did you purposely disallow auto-join?  If not, then your Options Bar Join Status must read "Disallow".  Change it.
Message 11 of 13
adveencha
Okay new discovery: It's only on walls with a 'Base Extension Distance' greater than 0' AND when the 'View Depth' & 'Bottom' in the 'View Range' is set to 'Unlimited'.
Given that it is happening in what I'll call a unique or uncommon scenario, I'm going to manually 'wall joins' all my corners and move on with life.
I have attached a file to illustrate it if you're curious to see what I'm seeing.
Thanks for your input everyone.
Message 12 of 13
Interesting finding.  Then you would need to miter join to fix those conditions.
