Wall Joins preception from REVIT
1 ANTWORT 1
Nachricht 1 von 2
201 Aufrufe, 1 Antwort
How do you can control this wall if its like that?Each wall join mode selected do not respond to the answer, and there is reason why he behave like that...and also do you know which is the solution for Revit Alignment shape whan you want to join some parts phisically but when Revit do this error message ( shape handle modify) : Can't keep elements joined. Im trying to align edge from different part in a way that will become a polygon  segmented but if coincident you cannot...
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
I'm not following you. Post the file.
