Wall Joins + Edited wall Profile
3 ANTWORTEN 3
Nachricht 1 von 4
jfjacques
324 Aufrufe, 3 Antworten
In plan,
How do I join 2 walls at a corner, both with edited profiles,
How do I join 1 wall at a corner, one with an edited profile, the other without?
If the default solution doesn't work, what should I be looking for?
( If my wall has an edited profile, I though it could it could join another wall (at a corner) if that profile ends in the center of this other wall's thickness and vice versa. This does not seem to often apply, could be wrong, does the placement of the edited wall's non-edited version matter? My solution is often to move the edited profile wall to the center of the other wall, and to pull the non edited wall to the exterior edge of the wall with the edited profile. Is this right? Doesn't always seem to work, though other things could be getting in the way like footings, walls below, hidden joins etc...  )
While on the topic of joins in plan, the "blue dot" supposedly indicate the wall end, is there a set of rules defining its placement?  Sometimes it is clearly at the end of the wall, otherwise on edited profiles it seems to demarcate the non-edited wall's end location and in the case of joined walls, It seems to connect in the center of the wall - does this indicate a join?
3 ANTWORTEN 3
Nachricht 2 von 4
kjskoog
als Antwort auf: jfjacques
Could you attach a revit file so I can look at it closer.
Thank you
Kory Skoog
PM/BIM Manager
Kory Skoog
PM/BIM Manager
Nachricht 3 von 4
kjskoog
Literally just need the 2 walls and anything attached to it.
Kory Skoog
PM/BIM Manager
Kory Skoog
PM/BIM Manager
Nachricht 4 von 4
jfjacques
als Antwort auf: kjskoog
I got these walls to work, I'll send something over if I can't join them in the future.
