i have a small section of wall which is having some issues, the wall steps out 200mm and the wall thickness is 300mm so this is causing some graphical issues whats the best way to solve this?
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Hmmm,
I'd say: don't make thick layered walls but seperate walls instead. But that is probably not the question.
Did you try "mitter" as wall join option?
not tried mitter, so you are also saying i should not use joined walls for this?
It is possible, for sure, but it needs some special attention ...
I'll upload a screencast in a bit.
First,draw the exterior 3 chained walls
Then draw the 4-th interior wall and play a little with Allow/Disallow Join options if necessary...
Constantin Stroescu
