Wall Join Problem
5 ANTWORTEN 5
Nachricht 1 von 6
PhilvK
576 Aufrufe, 5 Antworten
Wall Join Problem
I have a wall type that fillets correctly on the inside corners, 1st image below, but does fillet / join correctly on the outside corner. Anyone what I should look at to correct this please?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: PhilvK
Tap on the blue dot a few times or use the Wall Joins tool on the Modify tab.  Wall Joins.png
Nachricht 3 von 6
PhilvK
als Antwort auf: barthbradley
Thank you. I found that the issue was the wall had a Base Extension set for the substrate and finish layers. It filleted correctly after I set the extension to 0'-0". Thanks again for looking at it.
Nachricht 4 von 6
You shouldn't need to do that (e.g. zero out the Base Extension).  I wouldn't. We have conditions like that in all projects. Exterior Wall Finish Layers are always lower than mud sill/core.
Corner condition: One wall with -3" BE and other with 0":
Nachricht 5 von 6
PhilvK
OK, I'll work with it some more to see what else may be affecting the joining / filleting. Thanks!
Nachricht 6 von 6
BDMackey
When using the Base extension distance value the plan representation also works with the View Range.  I have seen the same issue and adjusting the view depth or view bottom would clean up the issue.
