Wall Join Problem
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
PhilvK
412 Aufrufe, 5 Antworten
Wall Join Problem
If someone has time to look at the attached file, is it possible to have the 3 wall types on the left join together as shown on the right with detail lines? I've been experimenting with different layer priority settings but can't seem to get it, especially at the clouded area. Thank you!
5 ANTWORTEN 5
Nachricht 2 von 6
blank...
als Antwort auf: PhilvK
Disjoin everything, trim lower and right, then upper and right, try wall joint command until correct result.
See attached.
Nachricht 3 von 6
David_Knight
One of your walls was built inside out.  IE: exterior finishes on the inside, and interior on the exterior.  Also your wall priorities were different than I use.  I changed them up.  Seems to be working for me now.
Nachricht 4 von 6
PhilvK
als Antwort auf: blank...
Thank you very much!
Nachricht 5 von 6
PhilvK
als Antwort auf: David_Knight
I switched the tile to same side...thank you!!!!
Nachricht 6 von 6
David_Knight
Check your wall priorities too.  This has great info on what they should be set to.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-1CCD1005-CBDA-4338-8D60-489095D4BB25
The meat of it is this:
  • Structure [1]: Layer that supports the remainder of the wall, floor, or roof.
  • Substrate [2]: Material, such as plywood or gypsum board, which acts as a foundation for another material.
  • Thermal/Air Layer [3]: Provides insulation and prevents air penetration.
  • Membrane Layer: A membrane that commonly prevents water vapor penetration. The membrane layer should have zero thickness.
  • Finish 1 [4]: Finish 1 is typically the exterior layer.
  • Finish 2 [5]: Finish 2 is typically for the interior layer.
