Wall Join Issue With Unlocked Layer
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
PhilvK
175 Aufrufe, 2 Antworten
The outer layer on the wall below is unlocked and as function priority of Finish 2 [5]. The inner light blue layer is locked and as function priority of Finish 1 [4]. Why is light blue layer doing what it's doing at the corner at the red arrow? Are Finish 1 and Finish 2 incorrect?Wall Join with Unlocked Layer.jpg
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: PhilvK
Use the Wall Join Tool on the corner return.  Allow Join.  Miter or Butt.   Clean Join or View Setting.
Nachricht 3 von 3
PhilvK
als Antwort auf: barthbradley
Thank you. Got it to work using miter and clean. Had to cycle thru a few times.
