wall join graphics
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
studioconverge
1898 Aufrufe, 9 Antworten
wall join graphics
How do I get rid of the line between the an interior wall perpendicular to the exterior wall in course scale view? I cannot insert a snip image of the plan example.
Tags (1)
Beschriftungen (1)
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: studioconverge
use the Linework (LW) tool.  But if the top one wall is below the cut plane of the view, that would be the correct representation.  If the cut plane is cutting through both walls, then use the Join Geometry tool or Allow Join to remove the visible edge between them.
Nachricht 3 von 10
PhilvK
Do you have 'Coarse Scale Fill Pattern' checked by any chance in one of the Wall Type Properties?
Nachricht 4 von 10
martijn_pater
Are these walls made of or using the same material?
Nachricht 5 von 10
cbcarch
Check if "disallow join" is active for the wall. Select the wall>Select the blue dot at the end of the wall>Right Click>Allow Join
When the wall is selected, you can also see a T-shaped symbol near the end of the wall for disallow/allow join.
The other possibility is if the vertical wall is in a linked model, the live perpendicular wall will not join to it.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 6 von 10
Mohamed-Nassar
use line work
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Nachricht 7 von 10
_Vijay
use join geometry switch geometry.
Nachricht 8 von 10
Mohamed-Nassar
or try to use Disallow Join to control the join method
Nachricht 9 von 10
studioconverge
als Antwort auf: PhilvK
It was the course scale fill. I had to make sure that all walls intersecting are either using or not using a course scale fill. Thanks.
Nachricht 10 von 10
martijn_pater
In case you don't want to use the course scale representation, just set your wall category detail level to medium/fine in Visibility Graphics for the view.
(Or vise versa if you do want to use course scale representation in another scenario with a medium/fine view, set it to course in Visibility Graphics for the view, wall category. Then make sure they're all the same course pattern for joining purposes.)
