Wall Join and Wrapping
5 ANTWORTEN 5
Nachricht 1 von 6
Rida_moukarzel
806 Aufrufe, 5 Antworten
Hello
Can anyone help me?
How can i obtain this result (see photo) without having these 2 thin lines in the red circle. I need the wrapping at ends and at inserts as shown in the photo.
Wall 1: CMU - Air - CMU - Plaster
Wall2: Plaster - CMU - Plaster
I really appreciate any help
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Rida_moukarzel
Nachricht 3 von 6
Rida_moukarzel
als Antwort auf: ToanDN
Thank you ToanDN. But i need to keep the wrapping at inserta and at ends as shown in the photo
Nachricht 4 von 6
Set your wall layers as the images attached. Remember that if your materials are not the same then you will see the line.
You can edit your wall joints from modify tab, Wall joints.
You can wrap your doors and windows from their own edit type, Wall Closure.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
Nachricht 5 von 6
Kimtaurus
Open the Visibility/GRaphics Overrides widnow for that view, and look at the Cut Line Styles at the bottom of the window.
Go to edit and set the Core layer clean-up to "No edge". If the wall's layers have the same material the lines should dissappear.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 6 von 6
Please check that the CMU in both walls has the same material name
If they have the same material name those two lines should disappear
