I was editing a brick veneer wall type and while adding split regions I received the following error:
Wall is shorter than minimum height allowed by its type.
It is 10' - 8" and must be at least 21' - 3 1/16".
I am unable to change or delete the problem wall.
What can I do?
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I was able to replicate this with no problem. Is it a stacked wall that you have - I have received this error message with stacked walls.
Try cutting and pasting the wall in the same location. A shot in the dark.
How about edit the wall type and modify the split region that works with shorter walls. Go back and delete that wall. Can you share a wall of that type so that we can see how the split region was built?
I'm able to edit the wall type for taller walls, but for the 10'-8" high wall I can't change it. When I try to merge the splits that would be above 10'-8" I get the same error.
Can you copy that short wall and paste to a new file and share? If not, do that for a taller wall and share.
OK. Your request got me thinking and I fixed it. I transferred the wall types to a new file. I changed the offending wall type there and then transferred it back. The wall I could not delete is not editable.
Thanks for your help.
