LinkedIn
X (Twitter)
Facebook
I am drawing a wall in plan view and found this problem:
It may be out of the view range. Switch to a 3D view, select the wall and show its properties here.
Hi @ToanDN ,
Thank you for your reply. Here is the 3D view of the wall:
What about the view range of the first floor plan? Check the view range bottom and view depth and make sure they are not below the associated level.
Hi @ToanDN
Thank you for your reply. I have edit the parameter as your suggestion and it works!
never-displayed
