Dear All
Maybe have an idea about a wall in revit, I want it to be like the picture in every architect wall interaction.
Because I will install Column structure.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Dear
Previously I've tried with Architectural Columns, but can't unless the column size is bigger than the wall
See GIF below
It works for both...If you use Architectural Columns they would join automatically... all you need to do is Use Switch join Order
