Wall instance sweep
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
546 Aufrufe, 5 Antworten
Wall instance sweep
I can add a walls instance sweep such as the Parapet Cap-Precast profile on the top of a wall that is viewed on elevation, as long as the wall is horizontal on top.
How to add the same profile to the same wall which is curved on top in some areas, like at the entrance, using the same instance sweep tool? (the profile sweeps attach horizontally and refuses to take the curve of the wall, and I do not see a separate tool to help it take the shape of the curved top).
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Use a model in-place to create the sweep.
Nachricht 3 von 6
als Antwort auf: ToanDN
Thanks,  Can any body advise of the steps or how to proceed?
Nachricht 4 von 6
Nachricht 5 von 6
I was able to follow the instructions and I then can see the sweep and the parapet coping on top of the wall on the 3D model, and also on the wall section and on the elevations.  The phasing caused me some brief preliminary trouble since by mistake I created the coping under "new construction", but then when I changed it to "existing" to agree with the existing phasing of the building the coping appeared well also in the wall section and in the elevation.
Great set of instructions.  Thanks a lot!
Nachricht 6 von 6
- Which category did you choose to create the in-place sweep in? Make sure the category is ON for those views?
- Did you create it under the same phase as the wall?
