Wall in cut with thick lines and dots
5 ANTWORTEN 5
Nachricht 1 von 6
teresa.afonso
293 Aufrufe, 5 Antworten
In plan views walls are showing with thick lines and big dots at the ends. Do you have any guess of what could it be?
I checked the line styles, templates, overrides and I cant find what is causing this.
Thanks in advance.
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
eizinmyat
als Antwort auf: teresa.afonso
How about trying like this? I think your problem is nearly the same.
https://forums.autodesk.com/t5/revit-architecture-forum/unwanted-dots-showing-on-wall-materials-in-f...
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
Nachricht 3 von 6
They're Model Lines that are perpendicular to the View. Hide them or change their Line Weight via Override Graphics in View by Element.
Nachricht 4 von 6
TripleM-Dev.net
Hi @teresa.afonso ,
Can you isolate the wall in question, could be easier to see what's happening.
Could be a join with other element/line override or Cut Override based on function (see image below)
 - Michel
ps. To identify what's causing it try setting some field to a odd color. This way it's easier to spot then with lineWeight
Nachricht 5 von 6
handjonathan
Hi @teresa.afonso
Thanks a lot for posting your question to the forums!   Has the solution suggested by @eizinmyat @barthbradley @TripleM-Dev.net helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 6 von 6
Use applied line work to the wall, using a line style thinner than the wall projection line weight.
