Good afternoon, I have a wall hosted family, it's a L-shaped kitchen,
I have this situation:
And I need to place more wall hosted elements like wall cabinets, BUT there is only one wall, I tried to insert an empty family wall to get my L-Shaped and it did not work. any suggestions please?
thank you
you should be able to place a wall and host your cabinets to it. then hide the wall in view (the wall will have to be hidden anywhere it is visible)? or put the wall on a workset and turn off the workset. the hosted elements should stay.
Howard Munsell
My recommendation is turn that wall into 1/8" (2.5mm) thickness which represent your wall tile. That way those object can be host in a group and you copy those everywhere.
@hmunsell there is no way to copy the wall or insert a new one. thanks
just following up please, any solution?
thanks ![]()
@GoldenGateNetwork wrote:just following up please, any solution?
thanks
2 solutions were given. Create a host wall and hide it in the view or use a "non-hosted" family.
A 3rd option might be to build onto your Wall-Hosted family.
try this 4th option:
Now this Family is Work Plane-Based. Test it. You'll have 2 Placement Options available when placing an Instance of it in the Project. Place on Face and Place on Work Plane. Choose Place on Work Plane and Place on Wall Face. In Plan View, Select Instance and use the Rotate tool to rotate the Cabinet 90 degrees.
I think that covers it.
or simply get pyRevit to turn any wall/floor/roof/ceiling based family to a face based family (and even to a non-host family).
@ToanDN thank you for your reply, I have the PyRevit pugin installed, I will try and I will accept solution if I am able to
thanks
edit:
11. Select Batch Copy=>Copy the Fixtures=>Continue copying fixtures, and then click Copy and select the one Instance of the Wall-Hosted Family. Then click Finish.
