Good afternoon,
I am trying to create a wall that is for a truck well. One end is approx. 3'-0" and the other is approx. 6'-0". Can I get the great minds out there to tell me if I can adjust a current wall type WITHOUT creating a new family?
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I have done this and there is not a place to put a second height. See attached example.
When you edit a wall profile, you see a purple outline, grip edit it to form the shape you need, even delete any lines and draw new lines. See screencast for changing the wall to 3' @ one end and 6' @ the other.
Your picture is not from Revit. It is from Autocad. You have posted in the Revit forum.
