Wall Height Doesn't Match Constraints
jtam43
jtam43
Hi there,
I am trying to adjust a wall height for my assignment, but am having trouble with the wall heights. I wish to set the foundation wall up to ground level. Maybe it's not correct yet, but either way, the point is still that the wall height does not seem to match the top constraints I specify. I have set the offset to 0 but still the wall height surpassed the top constraint. Can anyone tell me what I could be doing wrong here? I have attached a screen shot.
Thank you in advance!
RDAOU
@jtam43
Most probably the Top/Base of wall is attached therefore it no longer follow the constraints...Detach all and see if it reset to levels..
See GIF below...
The wall constraints set from Level 1 to Level 2 (no offsets) yet looking at the elevation it is extending from Level 3 to Level 4. Upon Detach, it resets to the constraints defined in the properties palette
jtam43
You are right, I realized later this might have been an issue. I ended up re-doing the wall but this solution you provided is a better approach. I didn't know of this attach/detach modification before. Thank you for this!!
Type a product name
