Wall hatches not showing in all views (plan view)
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
18652 Aufrufe, 8 Antworten
Hello.
I am working on a project with 3 levels (3 floors) i have made the walls from 2 layer gypsum with isolation.
The problem with revit is that i can see the wall hatching in ground floor, 1st floor, but when i draw the walls on the 2nd floor, there is no hatches.
- The view template is the same, and the weird part is that i can see the hatches in a section.
- There is no graphic overwright
- all plans are in fine, and the same scale.
Any of you have some kind of solution? :leicht_lächelndes_Gesicht:
Josh
8 ANTWORTEN 8
Nachricht 2 von 9
aleksei.tkachenko
als Antwort auf: Anonymous
Hello
Check that in the view template window you have ticks in front of Detail Level, V/G Overrides Model, View Range, Discipline.
Nachricht 3 von 9
Hello @Anonymous
Can you upload a picture of your view template settings?
Nachricht 4 von 9
Nachricht 5 von 9
Try to create again a view Temporary Template from Level 1 but this time remain the checked (see sample image). Once done and you've already correct the problem you can now delete the temporary template and put back the previous template you used.
Nachricht 6 von 9
aleksei.tkachenko
You don't need all ticks to be checked Smiley (überglücklich)
Nachricht 7 von 9
thanks. it worked
Nachricht 8 von 9
als Antwort auf: aleksei.tkachenko
Hello @aleksei.tkachenko
Well that's only temporary and will be deleted once the view has been corrected.
I tired and very time consuming to search in which the problem came from. so its better to tick all that box and mark as temporary template then delete it later.
Nachricht 9 von 9
i have also looked for the problem, tried only to select the right ones... but it is very time consuming and difficult when we are working on the clock.
