Wall hatches disapearing in callouts
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
1327 Aufrufe, 7 Antworten
hello,
I am trying to zoom in into some rooms using callouts, but then different hatches for wall layers disappear. It happens in some drawings only. Maybe someone know what might be the issue?
Same problem in Revit 2017 and  2018
7 ANTWORTEN 7
Nachricht 2 von 8
Sahay_R
als Antwort auf: Anonymous
Maybe changing the Level Of Detail to Fine would help?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 8
als Antwort auf: Sahay_R
thank you for a suggestion. it doesn't work though.. :enttäuschtes_Gesicht: I'm trying to see if that is something related to view templates. I've made to identical plan callouts. One of them display hatching properly and the other not. Can it be a bug?
Nachricht 4 von 8
Viveka_CD
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! Smiley (fröhlich)
Try changing the wall fill patterns to fine detail level views as suggested by @Sahay_R
However if you still face the same issue, I suggest that you try the following steps:
You mentioned ,"Same problem in Revit 2017 and  2018", so just making sure what is the version you are using currently?
Let me know if you have any questions.
Nachricht 5 von 8
Create a template from a view showing correctly and assign the template to the views showing incorrectly.
Nachricht 6 von 8
als Antwort auf: Viveka_CD
SOLVED! Wall pattern fills were overridden with solid white fill. Thank you for the help! :leicht_lächelndes_Gesicht:
Nachricht 7 von 8
Viveka_CD
Hi @Anonymous
I am glad to hear that it worked. Please feel free to let me know if you have any questions or concerns!
Nachricht 8 von 8
Hi- Where do you find the override fill? I am having the same problem when trying to apply layers to a callout in Revit.
Thanks!
