wall hang brick tiles
6 ANTWORTEN 6
Nachricht 1 von 7
sfDGPG8
328 Aufrufe, 6 Antworten
I am really struggling to make this. also looked in Youtube and different channels but no help. Tried to make it through curtain wall but couldn't .can someone please suggest me an easy way to make a wall hang tile. for reference i am attaching one image and Revit file.
6 ANTWORTEN 6
Nachricht 2 von 7
azad.Nanva
als Antwort auf: sfDGPG8
No really , there is no easy way, you can make them too easy , but openings like windows and doors make the problem and need too many work to fix them.
Nachricht 3 von 7
sfDGPG8
how you made this one if may i ask please?
Nachricht 4 von 7
azad.Nanva
I don't have R19 anymore so i can not share it with you , but i try to show you :
Nachricht 5 von 7
azad.Nanva
als Antwort auf: azad.Nanva
R23, that is what i have.
Nachricht 6 von 7
sfDGPG8
Thank you so much. much appreciated.
Nachricht 7 von 7
SteveKStafford
FWIW, usually this is not modeled, each tile etc. The finish layer in the exterior wall type would be assigned a thickness that corresponds with the overall thickness of the tile and it's rails, plus substrate, core layers etc. Then the material assigned to the finish layer would use a shingle fill pattern (model) to represent them in elevations. Details in drafting views would provide the close up information required. Building section views could also provide 2D elements to complete the more generic looking section that would be there by default.
Steve Stafford
