Fix what?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Lower the base offset of the upper walls or raise the top offset/ height of the lower walls.
For the portions where the floor edge is flush with the exterior wall face, you can use join geometry to remove the visible linework between them - assuming they are the same material.
Now, if the Walls the are compound-layered and the exterior layers are supposed to cover the floor edge below (e.g. exterior layers extend downwards), then you can modify the Wall assembly to unlock those outer layers and then, under the Wall properties, type in a negative distance value for Base Extension.
