Please see images, these little gap shows up randomly in the project (Revit 2019).
This is new construction, so the previous phase issue is ruled out.
The gaps are in any section of the wall, but it is not a full split. it stopped almost to the top.
Anybody encounters this issue before?
Thank you so much for any advice!!
Solved by lucdoucet_msdl. Go to Solution.
I tried to tab over it, it doesn't highlight the gap. The whole wall was highlighted.
Not sure additional information help, this wall is a demising wall and the room is enclosed and the room boundary is also looking good, without any issue...
@lucdoucet_msdl , these are stacked... so when I move the wall, the gap stays for a certain distance, ironically the whole room width. SO at some point, we thought it is a room boundary issue....
So the gap stays in the same place as you move the wall? This makes me think it seems like a hidden element interacting with the wall.
When you say "stacked", do you mean a Revit Stacked wall family or that the demising walls are aligned with each other from level to level (or architecturally "stacked"). The graphical representation of the wall in your axonometric 3D view does not seem to be a Revit Stacked wall as there is not distinction between the materials and/or thickness'.
Can you post the file?
-luc
@lucdoucet_msdl sorry about the wording confusion, it is just demising wall aligned floor to floor, not Revit stacked wall type. I already tried hidden element reveal and nothing there, cleaned.
Here is another wall and another view.
Thank you so much !
