Wall foundation VG n gap
6 ANTWORTEN 6
Nachricht 1 von 7
yes_and_no
343 Aufrufe, 6 Antworten
Guys,
How can I control wall foundation (structure) in view template ? I m sure this can be done because I can change their graphic rep by elements.
Also, due to door locations sometime the wall foundation automatically creates a gap. This gap in turn can be ungap by dragging either end, but never completely joined like that of normal architecture wall. Is there a solution to this ?
6 ANTWORTEN 6
Nachricht 2 von 7
GHASEM_ARIYANI
als Antwort auf: yes_and_no
hi
in the type properties of Wall Foundation > uncheck Do Not Break At Insert.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 7
yes_and_no
als Antwort auf: GHASEM_ARIYANI
Great,
Do you know how to assign their graphic appearance to view template ?
Nachricht 4 von 7
GHASEM_ARIYANI
Look at the numbers in the picture below:
Nachricht 5 von 7
yes_and_no
I don't think you can do a straightforward VG setting without a VG filter...
Thx anyway
Nachricht 6 von 7
Not clear what the problem is.
Nachricht 7 von 7
yes_and_no
als Antwort auf: ToanDN
For line type, ít won't work in view template (plan), in my project. I have to create a filter, not a big deal, just curious if it the same to everyone.
