wanted to stop the plaster layer of wall on floor finished....i tried all...its not happening with joint geometry and cut geometry....can see in attachment
Gelöst! Gehe zur Lösung
Gelöst von Mirko.Jurcevic. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von alberto-secondi. Gehe zur Lösung
Have you tried to assign the plaster layer Finish (5) in the section wall assembly?
The Floor finish should be a step above that in terms of hierarchy (1, 2, 3, or 4).
You need a Base Extension. Edit Wall Assembly and unlock the Wall Layer at Base.
Bro, there 's a video at the Link I provided. Around 2:30 they show what I am talking about.
Look at this picture.
