Hi everyone,
I made a single wall type consisting on:
Finish(5)
structure(1)
Finish(5)
When they intersect each other the cores appear to be joined on floor plan, that is ok, but when i go to section view, the finish layer keep showing instead of being cut by the core
I opened a clean new project and made the wall by duplicate a default generic wall and it happens on all intersections
Im using Revit 2021 on windows
thx everyone
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Thx for the answer it worked, but this problem happens on every intersection so if i have a larger project or a big section i would have to do this on every single wall intersection? i didnt have that problem before and it used to be automatically joined correctly before, so can it be something that im missing now?
thx for the reply
That's an odd Section Cut. Are you sure you're interpreting the Section View correctly? Maybe use a 3D Section Box to get a better look at the condition. Might make sense to you then.
thx for the reply
Disallow Join the wall and Join Geometry manually.
I did the section cut and it still showing the finish layer uncut by the core, I dont think this is normal i dont remember that happening before, i dont know what is going on anymore please help revit brothers
