Is there a way to add the SF of the walls in a room, not including the doors, and windows?
Ex: I want to get the surface are of the wall for paint or another finish, but I do not want to include the SF of the doors, and windows in that calculation.
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
Create a Wall schedule. You will be able to schedule for area. The area that you get will be minus openings.
Yes sure you can.
Please follow attached screencast.
Mostafa Elashmawy
Hi! And how to deduct openings ? I know that a workaround is to manually tag windows and doors by room, filter rooms and doors and use smart formula, and tag again, and guten tag ... but is there an automatic way ?
