Wall fills don't print out properly when printed to PDF
6 ANTWORTEN 6
Nachricht 1 von 7
B_Dorsam
322 Aufrufe, 6 Antworten
I am trying to print out a floor plan but when I do print it (using Revu Bluebeam) the wall fills are not printed properly. Several walls have no fill and some fills are moved around to other locations. I am attaching two screenshots below:
the view in Revit
the view when printed to pdf.
Also I dont use export because it tends to change the background color from white to slightly off white (254,254,254).
Any help is greatly appreciated!
6 ANTWORTEN 6
Nachricht 2 von 7
jay_colcombe
als Antwort auf: B_Dorsam
Does this relate?
Pages rotate when printing from Revit to the Bluebeam PDF Printer
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 7
mhiserZFHXS
Have you tried to native PDF export option yet?
Nachricht 4 von 7
B_Dorsam
als Antwort auf: jay_colcombe
I just tried this, but the same problem persits...
Nachricht 5 von 7
B_Dorsam
als Antwort auf: mhiserZFHXS
It works with export, but the reason we don't use export is because the white background gets changed from 255,255,255 to 254,254,254 and the printer reads that as a color - hence a more expensive cost.
Nachricht 6 von 7
ennujozlagam
try other pdf driver like PDF
Nachricht 7 von 7
curtisridenour
