Wall Filled
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
jorgedacunha60
1762 Aufrufe, 8 Antworten
Wall Filled
Good afternoon!
Someone help me out on this issue! I established and drew a wall on ground floor and 2nd ground floor.
On ground floor the wall showing blank and on 2nd floor showing filled. I need the wall showing filled on ground floor
and 2nd floor. I have attached both ground floor and 2nd floor.
George
8 ANTWORTEN 8
Nachricht 2 von 9
hmunsell
als Antwort auf: jorgedacunha60
is it the same wall spanning from Ground thru second floor? or do you have 2 sets of walls, one from ground to second and another from second to above?
  • in the second floor plan, go to the View ribbon > View Templates > Create template from current view.
  • the apply the new View template to the first floor
does the fill show up?
Howard Munsell
Nachricht 3 von 9
Maybe you are looking at the Coarse Fill/Color for the Wall. Change the Detail Level of the View to Coarse for both.
Nachricht 4 von 9
jorgedacunha60
als Antwort auf: barthbradley
Thank you for your prompt reply. I would like to show both floors
fill/color. In this case what do you suggest I do?
George
Nachricht 5 von 9
syman2000
Check and see if there is a filter or wall cut graphic override? If that don't help, upload the file so we can take a look.
Nachricht 6 von 9
If the orange fill is coming from the Wall's Coarse Scale Fill Color/Pattern, then change the View's Detail Level to Coarse to see the Coarse representation of the Walls
Nachricht 7 von 9
jorgedacunha60
als Antwort auf: hmunsell
Hi Hmunsell!
These wall are the same type, but they are 2 wall ( from ground floor to
2nd floor) and (from 2nd floor to ceiling)
Nachricht 8 von 9
hmunsell
what happens if you draw the wall from ground to ceiling? does the same thing happen?
Howard Munsell
Nachricht 9 von 9
oops...I noticed I circled the wrong icon in my last screenshot.
