Wall Family: modelling process
2 ANTWORTEN 2
Nachricht 1 von 3
XXalessio.amodioXX
222 Aufrufe, 2 Antworten
Hi all,
I have to model a family house with bearing wall, pithced roof.
I woul like to know, from your experiance, which is the best way to model complicated shape of bearing wall.
It is better to set the wall family using sweeps and reveal, divide in parts or prepare component in-place wall?
Whatsoever idea is welcomed.
2 ANTWORTEN 2
Nachricht 2 von 3
sweeps and revel is the best choice. because once you made this wall type you can use it whenever you like. While other options will require more steps.
Nachricht 3 von 3
als Antwort auf: XXalessio.amodioXX
I would need to understand what you mean by "complicated shape".  Generally, I "build" in the digital world the same way it will be built in the real world.  Can you post a picture/construction information?
