Wall Ends Showing as a different color with Shaded Display
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
5756 Aufrufe, 13 Antworten
Can anyone tell what I might be doing to generate this core color at the ends and tops of the walls?  I'm also attaching the file and some screenshots.
Any help is greatly appreciated.
Mike
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: Anonymous
Do you mean like this?
Nachricht 3 von 14
als Antwort auf: ToanDN
If you are talking about the five walls  on the leftish side of the image, that is what I'm talking about but I've been having a problem with the white walls of the OTHER structure in the file (to the south).  It is those that I can't seem to get to be all white in shaded graphics mode.  Glad to know you're on the case.  :leicht_lächelndes_Gesicht:
Mike
Nachricht 4 von 14
I see.  Paint them white then.
Nachricht 5 von 14
Thanks a lot.  I appreciate it.
I guess I'm not understanding how they got to be grey in the first place.  Do you have any idea what drove that?  Without looking a gift horse in the mouth, is there no more systematic approach?  I couldn't seem to see where that grey was coming from to begin with.
Mike
Nachricht 6 von 14
Actually, simply change Wrapping at Ends and Inserts to other than None.
Nachricht 7 von 14
That's what I'm talkin' bout!  Thank you once again.
Nachricht 8 von 14
PijPiwo
This grey color is a system default color (grey 127 127 127). Revit uses it for the objects that do not have material/color defined by the user - <by category> objects.
To change it, open object style window and apply material and shading color of your choice.
Nachricht 9 von 14
als Antwort auf: PijPiwo
Your explanation makes sense and is exactly the sort of thing that I thought was going on, but when I go to the object styles window and set the shading to a specific color, it doesn't change the core color.  I turned the wall wrapping off for this exercise.  I have struggled with a similar behavior with floor cores.  Still, your screenshot shows different behavior than what I'm getting.  What might I be doing wrong to NOT get the core to change when I assign a wall object style a specific color?  Any help is appreciated.  Would love to be able to work as simply as possible with these schematic designs until further complexity was warranted.
Mike
Nachricht 10 von 14
PijPiwo
Make a change in material browser, not object styles. Wall layers in your case have default wall material applied to them. You need to make a change to default wall material.
Also, change the shading to shading with consistent colors. You might be getting different color shading depending on lighting. It could be confusing especially with gray color that might look like white.
Hope it helps.
Nachricht 11 von 14
ja1357
I am using Revit 2019 and this method does not work. The one with wrapping in the ty
pe properties
Nachricht 12 von 14
als Antwort auf: ja1357
@ja1357 wrote:
I am using Revit 2019 and this method does not work. The one with wrapping in the type properties
It makes the difference here.
Nachricht 13 von 14
semhustej
I have created video describing the quirky behavior of wall ends material behavior. It also works for wall openings:
https://youtu.be/f-JhOUun3qg
Tom
Nachricht 14 von 14
serisita12
ayeeee you are the best
