Wall End Point does not match the end of the wall.
3 ANTWORTEN 3
Nachricht 1 von 4
jfjacques
1693 Aufrufe, 3 Antworten
The wall end point - the blue dot that is used to drag the wall- is not at the tip of the wall but a foot off the wall.
Why is this?
It is also eating into another wall, but as there is no wall present, there is simply a gap.
3 ANTWORTEN 3
Nachricht 2 von 4
Corsten.Au
als Antwort auf: jfjacques
Hi
Depending on which view you are in, the situations changes..
in Plan Wall End points  are easy to manipulate / stretch/ drag etc.
in 3D the Endpoint control ( blue dots ) are at the Base cause thats the CONSTANT/CONSTRAINTS
in Elevation - those controls becomes arrows to drag in either direction
of the wall..Example : Ground Floor - Offset Zero mm
If you change the ' BASE OFFSET " of the wall to say 500mm, then those dots /controls stays at the same location
but you can remove the conflict/overlapping of that wall with wall below..
Walls are level based / Plane based.. so each and every wall keeps those controls on that levels/plane..
move or create wall or required level and those controls will move to respective level/plane.
( Same goes for Roof as well... Idea is to select correct level and create floor/wall/roof.. simply moving them
up ex:3000mm etc won't change the Base constraint..
Each and every element in Revit ( some exceptions like mass ) are host based.. and hosts are
1. Levels
2. Reference Planes
3. Surface
4. Adaptive points
5. 3D elements within Model ( Surface of Wall, roof, furniture, mass )
etc
There is no independancy of elements in Revit, they need to belong to some reference to make it work..
Corsten
Building Designer
Nachricht 3 von 4
Are you talking about Plan Views or Section Views?
Is it a 'Blue Dot" or a Blue Arrow (e.g. Shape Handle)?
Have you created Parts from the Wall and have Parts Visibility set to "Parts"?
...let's build on those questions.
Nachricht 4 von 4
I had the same problem just now, but found a solution by doing this. If you right click on the blue dot and click "disallow join" the blue dot goes right next to the wall and the gap disappears.
