Wall deletes itself
2 ANTWORTEN 2
Nachricht 1 von 3
jfjacques
237 Aufrufe, 2 Antworten
Wall deletes itself
As I bring the wall into the corner,
Revit deletes it and unjoins other walls.
the ****?
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: jfjacques
just create the same type of wall and place wherever you want it to be and delete the other wall? thanks
Nachricht 3 von 3
syman2000
Wall join can be challenging especially if the wall span two storey and you have another wall at the 2nd level. Have use Architectural column? It works great and it will inherit the wall material when it get close to the wall.
