Wall Dashed Line affect material performance
mwang7DKXEF
Message 1 of 13
mwang7DKXEF
          I edit profile of the wall that can attached to the ceiling. but the dashed line is on the wall (that dashed line is shown original wall's level is 10'), when I use Paint Tool to add material on that place, the dashed line looks bother the material performance.  I want to remove that dashed line, I have no idea how should I do.
Thank you
Replies (12)
Message 2 of 13
jay_colc
Try checking the Hidden Line setting in the Properties.
Alternatively use the Linework Tool and click on the line and Set to Invisible
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 13
Attach Top of the wall to the ceiling instead of Edit Profile whenever you can.  If you insist on using Edit Profile, make the wall taller than the top of the profile so that the Unconnected Height line (dashed line as you said it) appears above the wall and doesn't bother you.
Message 4 of 13
mwang7DKXEF
Thank you so much. But that dashed line affect material performance. The wood has two different color because of that dashed line.
Message 5 of 13
mwang7DKXEF
Thank you so much. But I do not understand. Could you show me images?
Message 6 of 13
Did you read my answer?
Message 7 of 13
jay_colc
Please find guidance as requested.
Hidden Lines
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-E39CB6DD-7A32-4A91-95D6-E1E30FD0DD5E
Linework Tool (Invisible)
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-8979FAF8-8E25-4977-BFC8-0C065654CD0E
Jay Colcombe
Message 8 of 13
mwang7DKXEF
Yes, I did. It is bother me.
Thank you
Message 9 of 13
mwang7DKXEF
Thank you.
Message 10 of 13
Thank you
If you did then I don't think you read it carefully.  Did you try what I suggested in my post after reading it?
Message 11 of 13
mwang7DKXEF
"Attach Top of the wall to the ceiling instead of Edit Profile whenever you can.  If you insist on using Edit Profile, make the wall taller than the top of the profile so that the Unconnected Height line (dashed line as you said it) appears above the wall and doesn't bother you."
That is your suggestion. Now I know it is not dashed line fault. I will fix my material.
Thank you so much
Message 12 of 13
Thank you so much
Not sure why you need to quote my answer.  Did you do anything based on that answer?  That is what matters.
Message 13 of 13
mwang7DKXEF
do not worry. I just read your answers. and show you if I did correct.
Thank you
