Hi, I was wondering how easy it is to create a corner detail like this
It could be different sized bricks or stone
One option is to use Parts. Model the brick wall assembly then use create parts to split the brick layer and change it to stone or whatever material you need. This works if the stone thickness and brick thickness are the same, because this will only change the material, not the wall layer thickness. Make sure you adjust the Parts Visibility view parameter to 'Show Parts'.
Sincerely,
Andy Brack
Another option - line based family that uses a parametric array for the blocks.
The very first time you try to do it? It won't be easy.
Once you've got a bit of experience making a generic model, and nesting it into a line based family, and orienting/positioning it where you want relative to the line, and arraying it along the line correctly? It will be pretty dang easy.
