Wall Common Edge Draw Order - Gray common edges draw over outside cut line
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
hstaabprime
619 Aufrufe, 1 Antwort
I'm having trouble with common wall edge lines being drawn/printed over the outer wall cut line in plan view. I would like the common wall lines to be gray, but when I do so, these lines print over the outermost cut line.
Screenshot from Revit:
 Screenshot from PDF (printed with Bluebeam PDF Printer)
Yes, this would be imperceptible with a physical print. However, I very much would like the PDF to render as shown in the Revit screenshot. Any hints would be much appreciated.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: hstaabprime
Print with Bluebeam and choose Line Merge, Blend Mode = Multiply.
