Wall/Column/Material
zs-17
Message 1 of 10
zs-17
Hi
I created a new project, I installed columns 20*60cm, and I locked it on grids. When I installed the wall and connected it to a column, the material of the wall automatically added to the column. (column 1 only)
Few notes:
  1. The wall has a brick material on 1 side, when the column has the same material on 2 sides of 60cm.
  2. The material of column still exist even id I stretched the wall away.
  3. If I replaced the existing column with a new one, the material will shows up again on the new column.
  4. I have this problem on both Architectural and Structural column
  5. The material of column is set to By Category.
  6. I tried to use the Match Properties Tools, I can click on column 2 to select. But I can't click on column 1, the tool doesn't recognize the column 1, it's like if it doesn't exist.
Replies (9)
Message 2 of 10
Architectural columns are designed to take on the materials of what they are attached to.  Like if you want to create a brick pillar in a wall without having to add more walls to it.
Message 3 of 10
zs-17
I need a pillar inside a wall without material.
Message 4 of 10
Switch join order to remove the wall material from them.
Message 5 of 10
zs-17
How to do it please?
Message 6 of 10
See below.
Message 7 of 10
zs-17
My wall is thicker than the column and the walls are not aligned. That's why I didn't succeed to do it yet.
Message 8 of 10
zs-17
I figure it. Thank you
Message 9 of 10
CAn you tell me what you did to resolve the issue, when the column and wall has the same material that i want to change
Message 10 of 10
zs-17
If you use structural column, it will have automatically the same material of wall attached to it. If you use an architectural column, you will be able to apply a different material to the wall and column
