when working with floors, walls, structural columns and structural framing I always have this picture. look at the image #1. (this is the section but same overlap happens on the plan as well). then using join command i have to clear every spot like this to have clear image.
i wonder if there is a solution, revit automaticaly to join beams/columns from the wall and etc.
thanks in advance.
so i have to use join and switch join tool every time? there is no other way? I want revit to do this not me
fyi Archicad does this automatically
I don't know of any other ways. Dynamo maybe? But I am the kind prefers shifting through the gears myself instead of let the car do it so what do I know?
There is a Multiple Switch option.
You can use some plugins probably..
https://apps.autodesk.com/RVT/en/Detail/Index?id=2844467734357167732&appLang=en&os=Win64
