Wall Cabinets seem to disappear
6 ANTWORTEN 6
Nachricht 1 von 7
1851 Aufrufe, 6 Antworten
I am trying to add some wall cabinets in the kitchen and it dissappearevery time i click on the it, and yes it does snap to the wall,
any idea what the reason for that?
6 ANTWORTEN 6
Nachricht 2 von 7
Sahay_R
als Antwort auf: Anonymous
Are you talking about upper cabinets? Yes, you will not see them in plan because they are higher than the cut plane. One way to see a hidden line in plan would be to edit the upper cabinet family and add a hidden symbolic line. That will be visible in plan.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 7
ennujozlagam
@Anonymous hello, you can create a plan region and change the view range value for that area for better direction. thanks
Nachricht 4 von 7
als Antwort auf: Sahay_R
thank you!
Nachricht 5 von 7
How do I add the symbolic line?
Nachricht 6 von 7
Sahay_R
Edit the cabinet family - select the cabinet, click Edit Family.
In the family - go to plan view, in that draw the Symbolic Lines.
Click Load into Project.
You will only see the Symbolic Lines in a view that they are parallel to - in this case, Plan View.
Rina Sahay
Nachricht 7 von 7
Viveka_CD
Hi @Anonymous
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. - Thank you.
