Hi, I have added a wall element denoting a beam over, which I need to show as hidden lines on the plan. The wall is above the cut line so it does not show. It's above. Can I make it show hidden lines on the plan below?
Gelöst! Gehe zur Lösung
Gelöst von hmunsell. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von Redrunner92. Gehe zur Lösung
There is a common workaround used for roof overhangs which could be used here: first, turn on an underlay which shows the wall element above. Then use the Linework tool to change the outline to a dashed line, and after this turn off the underlay. The dashed lines will remain and will move along with the wall above if that wall moves.
you could use the Plan Region tool to place a box around the "Beam" and adjust the View range in the Plan Region to show what you need.
Howard Munsell
