Hello everyone, I'm having a problem here, I'm working in doing a Lighting Fixture Wall based, so I made the geometry in a non hosted lighting fixture family, because I was having problem when I was trying to make it directly in the wall based family. But now I can't see the geometry either in plan or ceiling plan, as you can see in the picture. I need to see it to make some detail lines, but there is no way to change the view range in the family editor, and I can't find a way to make the nested family in any type of plan.
Revit 2017, Windows 7
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
1. Draw the detail lines in the nested family.
2. Or, move the nested family down in the host family so you can see it to draw the detail lines. Then move it back up when done.
Thanks, I draw the line in the nested family, even though still didn't show in the plan, so I draw a vertical Reference line in the nested family, that way it showed in the plan, Thanks!
