wall based family under level behaves incorrectly
2 ANTWORTEN 2
Nachricht 1 von 3
PieterL_TM
98 Aufrufe, 2 Antworten
Hi everyone,
I have a wall based family which will be used to connect two wood panels (walls).
The issue occurs when changing the 'below_level' parameter.
In the family editor it behaves correctly, but when loaded into a project the family moves up rather than down.
How can I solve this issue?
2 ANTWORTEN 2
Nachricht 2 von 3
azad.Nanva
als Antwort auf: PieterL_TM
Control the under_level by Elevation from Level is the easiest way.
Nachricht 3 von 3
PieterL_TM
I know this is possible, but I have the same issue in other families in which I clearly want the parameter to offset the height compared the the reference level, so this isn't a good solution for my situation.
