Wall Based - Default Elevation parameter - Group Origin Level Offset
Hello there,
I am having a problem with elevations of wall-based families when there are in a group while changing the Origin Level Offset of the group.
All the wall-based families (except the ones that have Sill Height and Head Height parameters such as windows and doors) have default-instance Elevation parameter. When they are in a group and you change the Origin Level Offset parameter of the group, the Elevation parameter of the family changes randomly and not at all adjusted/relative to the change of the group offset.
Is there anyway to fix this other than loading a group with its owned levels?! Can I somehow connect the Elevation parameter to the wall instead of the level?!
P.S. I only tested it with Generic Models and Speciality Equipments as categories.
Thanks in Advance 😊
Tareq Al Khiamy
CAD/BIM Consultant
AEC Sweden
I don't know if I'm following you. Are you wanting the move the Group but not the Group Origin. If so, you can re-position the Model Group Origin. It's a blue dot in Elevation View.
Sorry for that. I will try to clarify more.
I need to move the group on Z-Axis. I am using the default instance parameter of groups: Original Level Offset.
The group contains a wall, a window attached to the wall and a generic model family as wall-based.
When I change the value of the Original Level Offset to the group, the wall and the windows move accordingly to the group but not the wall-based generic model family.
Check the attached photos. 😊
