Wall Assembly Section Modify Regions: How to separate finish from outer boundary
3 ANTWORTEN 3
Nachricht 1 von 4
1121 Aufrufe, 3 Antworten
Does anyone know how to unlock a finish layer from the outer boundary line?
Wall assembly is masonry wainscot and EIFS above. These are obviously not the same thickness but I cannot figure out how to move the finish face line of the EIFS separately from the masonry and outer boundary line.
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: Anonymous
@Anonymous
You can try to use Split Regions and Merge Regions in the wall structure...you should be able to achieve something very close to what you need...otherwise, I would recommend to use two different types of walls stacked on top of each other
Nachricht 3 von 4
als Antwort auf: RDAOU
Yes you can do this for any layer except the finish face. I've got work arounds, can model wainscot as separate wall or as sweep. Just not the workflow I was hoping for and not the solution for every instance.
Nachricht 4 von 4
RDAOU
@Anonymous
Workarounds? Define a workaround...for me a workaround is having to work out a solution using an external/3rd party app because none of what is provided in Revit works! Your OP didn't specify any preferences and the given suggestions were simply 2 different ways to have different finish layer thicknesses using different tools and options. From where we are sitting it is hard to guess what your preferred workflow is...
  • Use the split region mentioned above and unlocking the profile of the modified region will allow to manipulate the finish layer of that region - Image below uses this method
  • Adding an embedded reveal in the wall structure does the same
  • Adding additional Horizontal Reveals using the tool Wall: Reveal
  • Stacking wall types using System stacked walls
  • Stacking separate wall types manually
  • Using curtain walls with Basic walls as panels
