Wall assembly section graphics are not correct after being edited using split/merge region
1 ANTWORT 1
Nachricht 1 von 2
hliS658H
133 Aufrufe, 1 Antwort
The wall assembly section does not looks correct although it is correct in the section view of  Assembly Edit.  Total 3 layers, when split and merge with one layer, it looks right; merge with one more layer, the concrete loses the hatch pattern, and the most left layer gets the concrete hatch which it shouldn't.  Do not understand what has happened.
1 ANTWORT 1
Nachricht 2 von 2
vitorbortoncello
als Antwort auf: hliS658H
Layer functions have an order of precedence. The structure layer has the highest priority, Priority 1. Finish 2 has the lowest priority, Priority 5.
You could try adjusting the layers and cores.
ALSO… When merging, pay attention to the arrow direction
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
